Adler-32 Checksum
Message 1 of 9
(4,033 Views)
Hi MrFuppes,
have you tried to implement this yourself?
It seems pretty easy with just 2 shift registers in a loop…
Message 2 of 9
(4,028 Views)
Hi GerdW,
not yet, but will do so I guess if there are no "stock" .vi available...
Message 3 of 9
(4,024 Views)
Here's an implementation:
Message 4 of 9
(3,944 Views)
Hi MrFuppes,
you see: really easy!
You can delete the ArraySize node, autoindexing at the loop tunnel is all you need…
Message 5 of 9
(3,941 Views)
sure, & thanks. still need to get used to programming in LV 😉
Message 6 of 9
(3,937 Views)
Accepted by topic author FObersteiner
The Adler-32 solution by MrFuppes is incorrect for large data sets.  The high (B, s2) and low (A, s1) should be converted to U32 prior to the add and modulus.
Example:
"abcdefghijklmnopqrstuvwxyzabcdefghijklmnopqrstuvwxyzabcdefghijklmnopqrstuvwxyzabcdefghijklmnopqrstuvwxyz"
ADLER-32: 0x09832C7D
Message 7 of 9
(2,878 Views)
rcpacini,
thank you for reporting this! Kind of a stupid mistake... unfortunately it seems I cannot remove the code I posted. I've marked your answer as 'solution', I hope this helps.
Message 8 of 9
(2,255 Views)
Go to your post, click the "Options" dropdown, then "Report to a moderator". In that field, explain you'd like to remove the attachment since there's a bug, and they can edit the post for you.
Message 9 of 9
(2,245 Views)
