Custom Teststand UI: Preload Module Hangs when using DoClick Method
Hello everyone,
i have a problem regarding my custom Teststand UI. When i start my sequence Using the Test UUTs Entry Point (Entry Point 1 Button) everything works fine. But when i want to start my sequence with the DoClick Method on the Entry Point 1 Button, the sequence hangs at the "Preload Modules" Step.
What could be the issue of this problem ? I always thought the DoClick Method really simulates a Click on the Button ?
Thanks for your help.
Stevie
(3,848 Views)
Accepted by topic author StevieP
Dear Stevie,
try putting the DoClick method into a SubVI and configure its preferred execution system to something other than "User Interface" or "Same as Caller".
More information can be found here:
https://zone.ni.com/reference/en-XX/help/370052W-01/tsapiref/infotopics/lv_preferred_exec/
Andreas Gareis
Senior Applications Engineer, NI
Certified LabVIEW Developer & TestStand Architect
(3,737 Views)
Could you try using the execute method instead?  I have an example below.  My guess is if that doesn't work either, there's a problem with the sequence.
(3,730 Views)
Dear Andreas,
thank you for your answer. After i got no answer in the forum, i contacted the technical service, and they had the exact same solution for me and it worked. I forgot to post this answer in the topic, i'm sorry.
Stevie
(3,707 Views)
