06-10-2010 04:45 PM
Hi All,
I have a question which I can not seem to figure out the answer to. I am reading in a value and I multiply that value by 0.3 and 0.70 to set the minimum and maximum. I have also placed a vertical slider as well as a tank on the front panel. I would like to set cursors on the slider and the tank the indicates the maximum and minimum. I know that we can set cursors on waveforms but I haven't been able to do it on sliders and tank.
Please let me know if you would like anymore info.
06-10-2010 05:40 PM
I don't know if this will help. But I just played with the tank indicator and came up with this vi. It does not have cursors, but uses colors as min and max. I have 3 sliders 1=variable 2=min 3=max. I got 2 and 3 to fill to the min/max by playing with the fill style for each.
The verticle slider will actually have the slider handles on the side. Just add 2 more sliders to the slide and color them.
The other way would be to customize the indicator to make it just the way you want.
Hope this helped
06-10-2010 05:48 PM
06-10-2010 11:29 PM
