encoder spec for counting pulse USB 6008
In my current project I want to count the number of revolutions of a disc. We are using a optical sensor for this purpose and the output is 0v and 5v.
I tried to using the counter in MAX and also tried the count digital events.vi example, looked at other similar forums.
When I run the example, I dont' get any error but the counter output is zero only...
looks like problem is with the input..I connected the signal to analog i/p and I can see the pulses.. I dont understand why I can't get the counter to count the edges..Is there any other i/p siganl spec that i'm missing?
thanks,
Palkin
(2,628 Views)
Hi palkin,
 check the connection sproperly..where you have connected the optical sensor to the USB 6008.
Thanks and regards,
srikrishnaNF
Srikrishna
(2,621 Views)
