Ctrl-dragging to enlarge a structure in only one dimension
If I have the Position/Size/Select tool, and Ctrl-drag a rectangle inside any sort of LabVIEW structure, the structure enlarges in two dimensions according to the size of that rectangle.
I typically want to enlarge structures in only one dimension-- horizontal. It's rather difficult to drag a rectangle that is zero pixels wide; I must move my mouse so that it doesn't deviate up or down by a single pixel.
Is there some trick to doing this? I expected the Shift key would help, but no.
Message 1 of 9
(3,435 Views)
It's easy- when the dashed line disappears (with Ctrl-drag) you are at 0 pixels.
Message 2 of 9
(3,433 Views)
Correct, but sometimes just a split second before I release the mouse, the line appears again.
I'm hoping for some way to lock the drag horizontally.
Message 3 of 9
(3,427 Views)
Track balls are nice for that. Take your fingers off the ball before releasing the button.
But I agree that 1D expansion would be more convenient.
Lynn
Message Edited by johnsold on 08-16-2007 01:15 PM
Message 4 of 9
(3,421 Views)
I have to agree with Lynn 100%.  I use a track ball and that makes it a lot easier.  I laugh when I see someone struggling with a regular mouse.  But some people cannot get used to a track ball for some reason.  Just like they can't get used to the auto selection tool.  With a track ball, autoselection is much easer to use also.  I use the type of track ball where the ball is moved by the thumb.  Very good precision.
- tbob
Inventor of the WORM Global
Message 5 of 9
(3,402 Views)
Hmm, you guys have given me a compelling reason to try a trackball.
Message 6 of 9
(3,397 Views)
Lots of personal preferences. I prefer a trackball which is finger guided, rather than thumb, and I have never been able to get used to autoselection.
Lynn
Message 7 of 9
(3,370 Views)
tbob wrote " But some people cannot get used to a track ball for some reason.  "
I actually learned to use a trackball before mice were available (invented?).
The US Navy used a track ball on thier ANSPS-58A radar to allow an operator over a target and designate it to the missle fire control system. It was fun to use then, its still fun to be able to "throw" your cursor.
Ben
Message 8 of 9
(3,368 Views)
In fact, some people like track balls so much they have two of them Smiley Very Happy .
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 9 of 9
(3,363 Views)
