Creating subVI from Labview example
I'm trying to use a Labview example VI as a subVI in my projects. (examples/Vision/Image Processing/Image Treshold.vi)
I wired the path control and two image displays to terminals in the upper right of VI.
Then I created my main VI with one path control & two image displays, and add this  example VI in my block diagram.
The path control is working correctly but I can't see the images loaded in my main VI.
What am I missing there?
Thanks in advance.
(4,932 Views)
How did you modify the Example? The example has a loop so it will keep running until you press the stop button on the example and will only return a result to the caller then.
If you want to see the thresholding while it's running, you'll need to open the front panel of the SubVI - either from the VI properties, programmatically or by double clicking on it on the block diagram while it's running.
(blog)
(4,928 Views)
Do not just edit an example.  Make a copy of it for your project.
(4,919 Views)
I changed only the path constant with a path control, and wired terminals. You can see in attachment.
My aim is: I will put this VI in a case/event structure. When user press the button this VI will run in a different window (configured it as dialog), and user will make treshold and when stop button pressed, the original and treshold images will come into the displays in main VI. Then I need to use those images for further processing.
All working but images do not displayed in main VI.
(4,901 Views)
Accepted by topic author sevincom
Problem solved.
Just forgot to remove IMAQ Dispose VIs Smiley Tongue
Thank you for your interest and sorry for taking your time.
(4,872 Views)
