Creating front panel GUI
I need help in decorating my front panel. How do I insert arrows indicting directions. For e.g. if the output is a postive number point downwards else point upwards. I tried using 2D picture control but I am not able to drop the image into the box.
Thanks.
Message 1 of 11
(6,278 Views)
Hi S.,
There are functions to load images (like JPG, PNG, BMP) and to display them in a 2D picture indicator - use them!
You can also customize a boolean button to show your arrow images. Then all you need to do is switching the boolean indicator…
Message 2 of 11
(6,271 Views)
Have you looked at the Silver Palette?
Message 3 of 11
(6,234 Views)
Accepted by S.Neo
Try using a Picture Ring.
You can customize it (right-click Customize) and import images of your choice. Once created you can picture the right image by passing the appropriate number to select same.
Try it, you will like it!
Ben
Message 4 of 11
(6,233 Views)
How do you customize the boolean LED ?
Message 5 of 11
(6,188 Views)
Read this page about how to customize boolean controls/indicators: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YHctCAG&l=en-US
What I usually do, I look for nice and sharp icons in png format, and in the required pixel size to match with the size of my buttons. There are lots of repositories where you can get such icons for free, and they look very good. Usually I prefer the icons with minimalistic design plus transparent background 🙂 Here is one such site: https://www.iconfinder.com/search/?q=png&price=free
Here I show some examples I created in this way (I designed these rather huge buttons for a large screen application):
EDIT: but re-reading your very first post, what you need is Picture Ring as Ben suggested (so depending on certain conditions, you can programmatically set a Picture Ring indicator to show you directions, etc.)
Message 6 of 11
(6,179 Views)
No. Do what Ben suggested. Yes, you could use a customized LED indicator for a simple up/down arrow marker, since you have only two states. But imagine if later you need to add more states: like left/rigth, etc. If you use a Picture Ring from the beginning, your code will be much more scalable.
I show an example here how to use a Picture Ring ( https://www.ni.com/docs/en-US/bundle/labview/page/adding-picture-items-to-ring-controls.html ). If you use a Picture Ring from the "Classic" palette, you can even hide the borders (by selecting the brush tool, and using the upper right x symbol representing "transparent colour")!
Message 7 of 11
(6,174 Views)
Actually i was thinking of creating an animated arrow that will move up and down. I think pic ring is able to do it. But I'm not sure how to use it. Blokk, I am not able to open the vi as I only have LabView 2012.
Message 8 of 11
(6,162 Views)
Hi Neo,
i was thinking
Well, we can't guess what you are "thinking" - we can only answer your question in written form… 😄
When you want to have an "animated" arrow you can also draw it in a 2D picture indicator.
Or use a XY graph to draw your arrow: use complex numbers for coordinates and rotate the arrow by applying "simple basic complex" math… 😄
Message 9 of 11
(6,151 Views)
Find the VI attached in version 2012. So could you clarify what you want? You want a kind of animation, or just to show two different pictures: arrow up and down?
Message 10 of 11
(6,134 Views)
