Creating an illuminated flowpath on the front panel
I found them while poking around with scripting.
Haven't found much else particularly interesting except for some decorations.
The file "Decos.vi" has the interesting decorations.
The file "Object_Style_Ring.ctl" has the codes for all of the objects I've found.
Message 11 of 22
(2,130 Views)
Nice!
You should post an Idea on the Idea Exchange to include the pipes (controls and decorations) as part of the normal palette setup.
Richard
Message 12 of 22
(2,094 Views)
As I mentioned in an earlier post in this thread, atttached is an example of an illuminated flowpath using decorations, and also uses the UID scripting property node, as mentioned in this Micro-Nugget . It uses the pipes as mentioned above.
You need LV 2011.
Richard
Message 13 of 22
(2,061 Views)
I have been informed that my VI above is password protected. The password is "starbucks" without the quotes. Sorry about that! Smiley Surprised
Richard
Message 14 of 22
(2,043 Views)
The multi-segment pipe is bugged.
If you set its value with the value property node, the state will be reversed.
Try it.
Message 15 of 22
(1,989 Views)
Try it.
Please post a sample to illustrate.
Ben
Message 16 of 22
(1,975 Views)
Hello.
Try this VI to see this ugly bug Smiley Tongue
Message 17 of 22
(1,968 Views)
When I work with the pipes I seldon use them as booleans but rather drive the colors using the colros property nodes, so...
WHat exactly does not seem right to you?
Ben
Message 18 of 22
(1,958 Views)
grey = false
blue = true
but in mith multi-segment pipe + property node, we have grey=false then grey=true then blue = false
try my VI to see that
I don't care about the colors, my purpose is about the link beetween color and associated value.
Message 19 of 22
(1,954 Views)
Just an FYI that the bug SebastienM found with writing the value of a Multi-Segment Pipe indicator still exists in LabVIEW 2015 and the associated DSC module.  Just ran across it today.  Adding special code to work around this bug by inverting the value before writing it to Multi-Segment Pipe indicators via a property node.
Perhaps NI is leary of fixing this bug for fear of breaking code that has this type of workaround.
Hans
Message 20 of 22
(1,748 Views)
