Creating an array when you have the first and last element and the step size?
I have two input strings that give me the start and finish of some data, I also have an input string for the size of the steps between the elements, is there any simple way I can use this information to create an array or am I going to have to use loops?
Message 1 of 8
(4,939 Views)
Signal Processing >>> SIgnal Generation >>> Ramp Pattern.vi
Ben
Message 2 of 8
(4,932 Views)
... and
Functions >> String >> String/Number Conversion >> Fract/Exp String To Number, just to convert the range and step strings to proper numbers... 😉
Chilly Charly    (aka CC)
Message 3 of 8
(4,919 Views)
This is kind of working but I'm having problems when I get fractions , or my step size is even but I want to end on an odd number (starting from an even). Any ideas. Shall I start using loops, I'll probably try tomorrow, i'm getting tired now.
Message 4 of 8
(4,900 Views)
If sleeping in it does not help, then post images of your code so far so we can comment.
Hint:
There is a quotient and remainded funtion on the Numerics pallete.
Ben
Message 5 of 8
(4,893 Views)
Try changing the value of the "exclude end?" input parameter.
Tim Elsey
Certified LabVIEW Architect
Message 6 of 8
(4,891 Views)
If you have LV9 you do not need to use loops.  See the example.  You could change the controls to strings if you want, but I wouldn't.
Spoiler
There is nothing wrong with using loops.  This example is just for fun, the limits of LV recursion make the loop solution better.
About the last value, what do you expect the behavior to be?  Let's us say you have start 1.0, stop 2.1, step 0.2.  My example gives you 1.0, 1.2,...2.0.  Easy modification would include 2.2, but I don't think that makes sense.  Do you want 1.0, 1.2, ...2.0, 2.1.  Or do you want the step size adjusted and the number of steps fixed?  Too many combinations to mention.
Message 7 of 8
(4,889 Views)
@Pazmush wrote:
... or am I going to have to use loops?
What's wrong with loops?
Message 8 of 8
(4,873 Views)
