Creating a 'frames-like' environment.
I'm looking for a way to manage a larger program by using frames. What I'd ultimately like to do is have a high level VI that calls some other VIs based on some selections, but have the called lower level front panel VI load into a frame on the high level VI. The best analogy I could think of is like the old HTML frames.
If it's easier, I could even load the called VI in a new window. It's not preferable, but it would definitely do if it's an easier solution.
Thanks in advance. Any help is greatly appreciated.
(3,343 Views)
In LabVIEW there is a front panel component called a "sub-panel", and it can be referenced to do just what you are looking for. It is located in the "containers" sub-pallette of front panel controls. There is some help for the control and examples in the Help/Find Examples
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(3,337 Views)
Excellent, thank you very much!
(3,329 Views)
Also, creating real "frames" (aka "panes") by using splitters might be useful. You can move splitters to resize a pane and you can re-position the pane in order to "remove" content.
Using splitters and subpanels together is obviously the best option for a clean, useable UI with more than a bunch of elements, esp. when using plugin-architecture for adding stuff later on.
Norbert
Norbert
Expert: Geometry
(3,287 Views)
