Create an executable build for eurotherm instrument driver
I would like to know if anyone has or can create an executable build from the instrument driver for the eurotherm 3216 Temperature Monitoring Control vi.
I have downloaded the file from the NI website http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=7F14CDCB24923797E04400144F1EF8...
It runs fine when I run the VI from the project explorer, but the moment I create an executable build and load the application, I constantly get this error, Error 7 occured at open File+.vi:Open File.
I will be glad if someone can help.
(3,895 Views)
If you upload some code it will help us to understand, I think Error 7 is related to some file missing from expected path.
This may run properly when you run VI, because all file are at specified location but when you create executable the path may not be same.
Make sure your run time path should be properly assigned.
With Regards
Miraz
Kudos is better option to thank somebody on this forum
(3,889 Views)
This is my simple code using the driver. You may have to download the driver from the NI website first using this link http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=7F14CDCB24923797E04400144F1EF8... and then unzip my file and run the Eurotherm Temperature Control Monitoring vi from the project.
This will work fine without the Error 7 popping up. But when I create an executable buld and run the application, I get the Error 7.
(3,867 Views)
Duplicate thread: http://forums.ni.com/t5/Instrument-Control-GPIB-Serial/Create-an-executable-build-for-eurotherm-inst...
(3,852 Views)
Hi
Thanks, I will take a look at your solution as well. However what risk will this have on the driver?
(3,844 Views)
Accepted by topic author dexterpoet
Mostly you having to maintain the driver and making sure that update is put on every machine that could possibly need it.
(3,839 Views)
Hi
Thanks.
I have modified that particular vi and the executable build now runs on my development pc. The next step is to now build an installer and try it on a stand alone pc. As it is close of work here, I cannot try this on a stand alone pc today so will have to give you feedback on Monday.
Thank you.
(3,823 Views)
