Counters
Hi Everyone
I am trying to make two separate counters on a true and false case structure. I want to count every time the true and
false case occurs and then do logic on the counts outside of the structure.
I have done research and saw that you can put shift registers on the edges of a while loop and put the case structure inside.
But it does not seem to work when I want to output the two different numbers each time the while loop runs.
Does anyone know what I can do or what is wrong? Do I just need one pair of shift registers or two?
I am using LabView 2010.
Best Regards
(3,746 Views)
Try this and let me know it this what you are looking for.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(3,714 Views)
Accepted by Midna19
Ranjeet_Singh 's solution will work but I would recommend using shift registers as per your original thought.
Here is a slightly modified version:
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
(3,703 Views)
Why you recommend this, Just asking ?
--Ranjeet
(3,697 Views)
I didnt read the problem properly and give solution in slightly different way. My apologise.
Instead of counting true and false case counter I gave true and false counter.
--Ranjeet
(3,696 Views)
Thank you .aCe. and Ranjeet_Singh!!
Sorry Ranjeet_Singh but I could not see your VI since you have a later version of LV but .aCe.'s solution worked for me. 🙂
I was able to keep the increment for each case in the loop and do logic outside.
I was just using one pair of shift registers and I also did not connect the wires in both cases correctly.
xxxMidna19
(3,671 Views)
