Read encoder signal with 9201
Hi
I have a quite uncommon problem. I need to acquire the encoder signal with a NI-9201 (analogue module).
Is this even possible? Of course I saw I that I should use a NI-9401 but my chassis is full...
I already tryed to acquire impulse signals with such a module but they were slower.
Thanks for any help.
Yves
(2,984 Views)
Hi Yves ,
Maybe did you try with different method without the DAQ assitant?
Boldness has genius, power and magic in it!'
(2,975 Views)
Hi Maveen
Yes, I already did some kind of measurement without DAQ assistant. And it worked. But I'm not sure it'll work with an encoder signal which has a higher frequency.
(2,969 Views)
Hi Yves,
when you acquire data from an encoder, do you mean a quadrature encoder or rotary encoder?
This encoder generates a binary or digital signal.
Of course, you can always acquire a digital signal with an analog input module. This isn't recommended and necessary when you can use a pre-built api in the palettes for digital modules.
When there is no free slot you can think about an expension chassis or a single carrier. This depense on your application.
How did you acquired the slower signal until now?
Kind Regards,
Philipp K. | NI-Germany
(2,939 Views)
Hi Philipp
Thank you for your help.
The encoder generates a rotary signal (A-Phase, B-Phase). The signal itself has sinusoidal with 5 VDC peak.
Well, I haven't evaluated the possibility of an additional single carrier. Actually the system is built up with a cDAQ 9172. Maybe I should consider this too.
The last time I acquired turbine signal (approx 200Hz) I did this with a analogue channel. The I processed the signal by using two triggers (one for rising and one for falling). This gives me absolutely accurated values.
Yves
(2,923 Views)
Hi Yves,
can you attach any VI or screenshots.
Philipp
(2,907 Views)
