Copying control attributes
Hi
I've got a VI set up where I'm transferring various attributes from one control to several others, using property nodes. Since the list of attributes is getting quite long, I wondered, is it possible to do the same thing using a reference or some other method instead? (I'm using LV7.1).
Appreciate any advice,
Bruce
(3,172 Views)
Is there a reason why you're trying to do this?
Kind regards,
- Bjorn -
Have fun using LabVIEW... and if you like my answer, please pay me back in Kudo's 😉
LabVIEW 5.1 - LabVIEW 2012
(3,165 Views)
Try something like this.
(3,148 Views)
Hi Bjorn
The VI is part of a prompt to allow details to be entered from upto 7 different units under test. For each unit, I have various controls for inputting information, on individual tab pages to separate everything out. Since the hardware in the units can vary, I wanted a way of modifying all relevant controls to highlight the fact that there are differences. At the moment, I use several master controls and transfer the attributes from those, but I just thought there must be a better, more efficient way of doing this.
Kind regards
Bruce
(3,111 Views)
Hi pcardinale
Thanks for that. You couldn't send it again in LV 7.1? Unfortunately, I've not got Labview 9.
Kind regards
Bruce
(3,110 Views)
I can only go back to LV 8.0
(3,096 Views)
Hi pcardinale
I got the file converted to 7.1. Thanks alot, that's just what I was after.
Bruce
(3,064 Views)
