Copy files in a shared folder
HI all,
I have an application in which I have to copy a file in a shared folder on a different PC over the same network. Can anyone suggest me How to do this?
Labview user
(3,857 Views)
Well, the easy approach is to generate the file locally and then use the COPY function to add the file to the network drive.
But there are some caveats:
- How do you make sure that you have the correct permission to write the file there?
- How do you make sure that the path to the shared drive is valid (e.g. mounted drive vs. absolute path)?
- How do you plan to react if the file already exists on the network drive?
hope this helps,
Norbert
Norbert
Expert: Geometry
(3,841 Views)
Hi Norbert_B
thanks for your answer.
However apart from your described caveats I have on more
How to get acknowledgment when file has been written. Can you suggest som way?
Labview user
(3,817 Views)
@Aojha wrote:
Hi Norbert_B
You will typically get an error if the file was not written.  But I want to say I ran into a situation where it didn't.  Can't remember.  Just check for an error on the copy.
(3,809 Views)
Hi guys,
I'm trying to figure it out as well. I need to give a password before copying files, how can I do it in labview?
(3,780 Views)
