10-27-2021 09:21 AM
returned string results from an instruments with VISA are always returned with a point.
Depending on the windows installation they must be converted to a value with a comma.
Attachached an snippet of a conversion.
Will this work for all regions? (Using a comma or point)?
What is the meaning of the %Le ?
10-27-2021 09:37 AM
Comma or point makes sense only for string conversion. Numerically across the world, the value does not change. Now, when you convert this number again to a string, at that point you've to tell the string format function to use the local decimal separator.
In the snippet you've shared, it looks for a value with a dot separator and converts it into a number. You can understand what each specifier means by double-clicking on the Scan from String function which displays the window as shown below.
10-27-2021 09:49 AM
Yes, i want to convert a string to a numeric value.
The string is returned from the instrument and i need it as a numeric value.
Depending on region settings the string 1.23 should be converted to "1,23" or stay on "1.23".
What is the meaning of the "L" in the format specifier?
10-27-2021 11:15 AM - edited 10-27-2021 11:18 AM
A number is a number. They are represented as bytes in memory and have no format until a human needs to see it. If you want to display it as something other than what your localization settings tell it to display it as, convert it into a string with that decimal format specifier.
11-04-2021 04:43 AM
11-04-2021 08:31 AM
Click on the "Help" button to find out.
11-04-2021 08:44 AM
Help for "Scan Value, format specifier syntax" was not helpful regarding the "L".
11-04-2021 08:58 AM
"%Le" conversion code had me stumped as well... and I have been using LabVIEW for a very long time. LV help provides a lot of different values but "%Le" is not one of them.
I had to resort to googling the meaning, and it turns out that it is just a "Long Double". Some archaic C formatting code.
%Le long double x (long double)x
Found it on this page.
11-04-2021 09:04 AM
I cannot find anything on "L" in the help. Is it for "Long?" Is it a unit? LabVIEW does not complain when it's there, but I could not find an effect despite of many attempts.
11-04-2021 11:08 AM
My apologies, OnlyOne. I had no idea it wasn't available from the dropdown menu (and therefore, not in the help file). I did not consider that the format specifier was added manually.
