Converting instrument string result to float
returned string results from an instruments with VISA are always returned with a point.
Depending on the windows installation they must be converted to a value with a comma.
Attachached an snippet of a conversion.
Will this work for all regions? (Using a comma or point)?
What is the meaning of the %Le ?
Message 1 of 10
(3,518 Views)
Accepted by OnlyOne
Comma or point makes sense only for string conversion. Numerically across the world, the value does not change. Now, when you convert this number again to a string, at that point you've to tell the string format function to use the local decimal separator.
In the snippet you've shared, it looks for a value with a dot separator and converts it into a number. You can understand what each specifier means by double-clicking on the Scan from String function which displays the window as shown below.
Santhosh
Soliton Technologies
Message 2 of 10
(3,499 Views)
Yes, i want to convert a string to a numeric value.
The string is returned from the instrument and i need it as a numeric value.
Depending on region settings the string 1.23 should be converted to "1,23" or stay on "1.23".
What is the meaning of the "L" in the format specifier?
Message 3 of 10
(3,491 Views)
A number is a number.  They are represented as bytes in memory and have no format until a human needs to see it.  If you want to display it as something other than what your localization settings tell it to display it as, convert it into a string with that decimal format specifier.
Bill
CLD
(Mid-Level minion.)
Message 4 of 10
(3,471 Views)
Message 5 of 10
(3,412 Views)
Click on the "Help" button to find out.
Bill
CLD
(Mid-Level minion.)
Message 6 of 10
(3,405 Views)
Help for "Scan Value, format specifier syntax" was not helpful regarding the "L".
Message 7 of 10
(3,397 Views)
"%Le" conversion code had me stumped as well... and I have been using LabVIEW for a very long time. LV help provides a lot of different values but "%Le" is not one of them.
I had to resort to googling the meaning, and it turns out that it is just a "Long Double". Some archaic C formatting code.
%Le       long double x  (long double)x
Found it on this page.
Message 8 of 10
(3,390 Views)
I cannot find anything on "L" in the help. Is it for "Long?" Is it a unit? LabVIEW does not complain when it's there, but I could not find an effect despite of many attempts.
Paolo
Message 9 of 10
(3,387 Views)
My apologies, OnlyOne.  I had no idea it wasn't available from the dropdown menu (and therefore, not in the help file).  I did not consider that the format specifier was added manually.
Bill
CLD
(Mid-Level minion.)
Message 10 of 10
(3,373 Views)
