Converting data from MySQL database to usable values
After connecting to the database and retriving data out of it. How do i do something to it ? Like for example i wanna do an addition with the values obtain from database.
Message 1 of 13
(6,473 Views)
-Try Database Variant To Data Function https://www.ni.com/docs/en-US/bundle/labview-database-connectivity-toolkit-api-ref/page/lvdatabase/d...
-After converting to Labview data of type 2D array you can do all operations on it.
uday
Message 2 of 13
(6,460 Views)
Hi Uday,
I tried doing this, not sure why it didn't work.
Message 3 of 13
(6,413 Views)
To the "type" terminal connect 2D array of constant of numeric
uday
Message 4 of 13
(6,410 Views)
Just to check u 2d array of numeric is 2d number array right ?
Message 5 of 13
(6,405 Views)
Accepted by S.Neo
If the data is of string need to provide 2D String Array as reference to the Variant.
Message 6 of 13
(6,403 Views)
Yes i meant 2D number of array.
-I double checked actually palani, before posting whether i should say of strings or numbers then i saw addition in OP first post and hence i didn't touch strings.
Edit: If you need help : http://www.ni.com/white-paper/7571/en/
uday
Message 7 of 13
(6,398 Views)
Thanks uday,
As the variant value seems to be String i just wanted to make sure if its string better to use string array as reference.
Message 8 of 13
(6,390 Views)
Even though I have solved the problem but I still have a few question which i don't understand. Hope u could help me.
1) Why is it a 2x2 array ?
2) How do i take a selected value for example. i only want to the value 3333 to be taken out from database.
3) How do i add the 3rd (3333) number and 4th (4444) number from database after getting the value out from array?
4) I am a beginner in labview and all other programming. Is there any way to learn ?
Thank you.
Message 9 of 13
(6,340 Views)
@S.Neo wrote:
Even though I have solved the problem but I still have a few question which I don't understand. Hope you could help me.
1) Why is it a 2x2 array ?  You could be asking for multiple columns and multiple records.  The functions need to handle that possibility
2) How do i take a selected value for example. i only want to the value 3333 to be taken out from database.   Index Array function
3) How do i add the 3rd (3333) number and 4th (4444) number from database after getting the value out from array?  Add
I would recommend looking at the online LabVIEW tutorials
LabVIEW Introduction Course - Three Hours
LabVIEW Introduction Course - Six Hours
Thank you.
Message 10 of 13
(6,318 Views)
