Converting data from MySQL database to usable values
1) Why is it a 2x2 array ?
- A table is a collection of related data held in a structured format within a database. It consists of columns, and rows.
2) How do i take a selected value for example. i only want to the value 3333 to be taken out from database.
- You can use Index Array and give proper row and column index to get the element in array.
3) How do i add the 3rd (3333) number and 4th (4444) number from database after getting the value out from array?
-After indexing elements you can use Add Function
4) I am a beginner in labview and all other programming. Is there any way to learn ?
- There are free online tutorials available:
LabVIEW Introduction Course - Three Hours
LabVIEW Introduction Course - Six Hours
Learn LabVIEW Basics
NI Learning Center
[1K Post]
Edit: Also you can check the examples shipped along with labview Help->Find Examples and Context Help by pressing Ctrl+H.
uday
Message 11 of 13
(1,337 Views)
Hi Udka,
I want the data to up date every 1 min interval is there any better way going about this beside adding a while loop to it ? If I were to use while loop, the program will have to open and close the database every loop while i think it is not very practical. But i can't think of another way to do it.
Message 12 of 13
(1,297 Views)
You can create a VI With different cases as OPEN, READ,CLOSE of database, Keep the Reference in the shitregister, call the OPEN and CLOSE cases before and after Loop, call READ case Inside Loop.
Message 13 of 13
(1,290 Views)
