Converting a labwindows driver to labview
http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=E3B19B3E9628659CE034080020E748...
I am trying to convert the labwindows driver found at the link above to labview (8.5) and I am trying to do this via the tools-->instrumentation--->Create VI interface to LabWindows/CVI instrument driver.
If I select "Basic" to do the conversion, I get an error message saying that it is not a valid .fp file or the file version is too low.
On the site it lables the driver as being from labwindows/CVI version 6.0, which has worked for conversions before.
If I select "Advanced" I notice that althought the .h file is present, the .sub file is NOT.
My trial version of CVI is expired, if I uninstall and reinstall will I be able to generate a .sub file?
Or is there another way to make this driver work?
Message 1 of 9
(4,461 Views)
I went and downloaded the Labwindows trial to another computer and generated the .prj .lib and .dll files, but the labview tool to make a driver still doesn't work.  I get the same "not a valid .fp" error message.
Message 2 of 9
(4,449 Views)
Hello Lars
The following link will teach you exactly how to do it:
How Do I Convert a LabWindows™/CVI Plug-and-Play Instrument Driver for use in LabVIEW?
Mart G
Message 3 of 9
(4,431 Views)
Yeah, I've gone to that link and I've done these conversions before. It still tells me "not a valid function panel" when I select the .fp file.
Message 4 of 9
(4,422 Views)
Hello Lars,
Gonna try to convert it myself and let you know
Mart G
Message 5 of 9
(4,417 Views)
Accepted by LarsUlrich
Hello Lars,
I saved the .fp file using CVI 2010 and now the error is gone when using the wizard. Attached you will find a fixed zip file.
Mart G.
Message 6 of 9
(4,404 Views)
Thank you so much for your help, did you see the same error as me before you saved it with CVI 2010?
Message 7 of 9
(4,402 Views)
Yes, before I saved it in CVI 2010 I got same error when using the wizard.
Mart G.
Message 8 of 9
(4,398 Views)
Hi there , could you please send the link again....it doesn't exist anymore
Message 9 of 9
(3,165 Views)
