Converting LV Time Stamp from Excel
Yes I misunderstood. I am able to duplicate the behavior you are seeing in Excel 360. Trying a couple of things now.
Now Using LabVIEW 2019SP1 and TestStand 2019
Message 11 of 22
(2,491 Views)
I know - I've been doing this for 20 years myself and have never seen this behavior from Excel - weird huh!
Message 12 of 22
(2,481 Views)
So you have to do the math on the double before you paste or post it into Excel. I had just tried to Get Date/Time and convert to double to display in a numeric. Copy that direct as text into Excel will not convert as was mentioned. Quick snippet to show if you copy "Direct Copy" vs "Direct Copy post" and try to format as time.
Message 13 of 22
(2,472 Views)
If you use ActiveX and send Excel the LabVIEW Timestamp format (brown wire, coerced into Variant at the Value2 Property node) then it will convert it for you. Otherwise yes you need to do math to convert it (and handle some exceptions).Timestamp To Excel Snippet.png
I would assume dotNet is similar.
Message 14 of 22
(2,448 Views)
Basically the LabVIEW timestamp is number of seconds since January 1, 1904 GMT. An Excel timestamp is number of days since January 1, 1900 with a little anomaly that they "forgot" about that 1900 was not a leap year. Supposedly this is the same definition that was used in the Lotus 123 software too, so it is most likely not so much about forgetting the leap year rules by the Excel developers as rather wanting to be compatible with the market leader back in that time.
Apple avoided the problem of the irregular leap year by moving the epoch for its timestamp 4 years into the future and LabVIEW adopted that since LabVIEW was originally developed on Macintosh and therefore used that format for timestamps.
Rolf Kalbermatter  My Blog
Message 15 of 22
(2,440 Views)
Something to think about:
Rather than remembering the formula and constants to convert the time stamp to seconds from Jan 1, 1904 (or is it Jan 1, 1900??), I format the timestamp directly to text. Don't know which method is better or worse, slower or faster. But that really doesn't matter since the Write to Excel will be many orders of magnitude longer.
I've been doing it this way for over 20 years without any problems. The only manipulation of the timestamp I do would be changing it from local to UTC. You would also need to make an exception on the days that time changes from Standard to Daylight Savings Time (or vice versa). My simple workaround is to always set my computer's "Time Zone" to UTC. Problem solved.
NOTE: everyone seems to use %f for the format string. That defaults to 6 decimal places. In the below example, that round off error shows up as a delta of about a 16ms from the Excel to LabVIEW timestamp. The delta could be more or less depending on the amount of round off. My understanding is that Windows time is not accurate below 10ms anyway. But if that delta matters, then you should use something like %.9f. The direct text format saves it to 10+ digits, and the timestamps always match down to the millisecond.
Message 16 of 22
(2,414 Views)
It sure does present some challenges, the first is understanding the differences between all these platforms.
Wonder why there are no official NI vi's included with LabVIEW that deal with coding challenges like this that a lot of developers run into and have to reinvent the wheel over and over again - rhetorical question.
Anyways, I gathered some bits and pieces and this is what I came up with to work in my time zone which is where the app will function for its lifetime - I had tweak the timestamp constant to get to my zone, the case structure deals with DST.
Thanks to all for your input and help!
Message 17 of 22
(2,399 Views)
Hey, I believe Altenbach said there was a time when you couldn't delete wires, so consider yourself lucky!  😄
Bill
CLD
(Mid-Level minion.)
Message 18 of 22
(2,381 Views)
Most likely because it is an almost unsolvable problem really. There used to be some VIs around even from NI that did this, hacked together and working if your Windows country settings were just right, AND your timezone wasn't off from CDT (Texas time) AND the summer time wasn't configured differently in your system AND a few other things.
Taking all these things into consideration even without accounting for even more weird custom settings in Windows that can throw this off even more, and "improvements" in time handling in Excel over the years in new versions is already a huge challenge!
Message 19 of 22
(2,372 Views)
Accepted by FishBonze
It is in fact an problem that cannot be Universally solved .
See Promote Functions on Timing pallet IDEA EXCHANGE 💡 for reasons
Time to XL.vi and Time to Time of Day.vi are available there
The Link further on to the code sharing repository has since been subjected to "user experience improvements." But I was able to resurrect this location containing the XL to Time.vi inverse of Time to XL.vi
For all use cases where the Target's Civil Time is the same as the development machine Civil Time these vis will work.   For all cases where the Civil Time is under the same legal jurisprudence the behavior is predictable at development time and a copy of Time to XL With modification to the time constant can guarantee behavior by quering local zone information.  E.g. all United States Civil Time is coordinated from the US Naval Observatory but East Tambor writes its own laws to govern Civil Time.  Microsoft, Apple, et al apply any changes to those Laws as they see fit with patches to Localization settings in the OS.
"Should be" isn't "Is" -Jay
Message 20 of 22
(2,336 Views)
