Converting LV Time Stamp from Excel
So used the "Get Date/Time in Seconds.vi then converted it to a DBL and used this to write the timestamps in Excel and that works fine,
I need to know the formatting in Excel  to display the number as the original timestamp. I've tried using the "format cells" from the dropdown menu then chose "custom" from the category and tried entering what I thought would be the correct formatting but it can't convert and returns pound signs instead.
Does anyone know the format string to get the time stamp back to the original?
Thanks in advance.
Message 1 of 22
(3,234 Views)
Literally the first hit in google.
https://forums.ni.com/t5/Example-Code/LabVIEW-Time-to-Excel-Time-Format/ta-p/3503346
Make sure you read the comments about how to handle the time-zone difference too.
Message 2 of 22
(3,224 Views)
Thanks - think I could find that on this sit - LOL!!
Message 3 of 22
(3,187 Views)
If you are saving your timestamp like this:
In Excel the "raw" timestamp should look like this:
Highlight the column and select the format you desire:
That changes it to this:
Here's the same timestamp in another format:
Select "General" to change it back to the "raw" timestamp.
Back to raw...
If this does not work the same for you, then you are probably not saving your timestamp with enough digits of precision.
=== Engineer Ambiguously ===
Message 4 of 22
(3,169 Views)
Thanks - that makes sense and I just checked on the digits of precision and it is set to 6 digits - hw many digits are needed to save a time stamp?
Message 5 of 22
(3,153 Views)
I am not really sure... I don't mess with precision, I save everything in full precision.
Here's what one of my raw data files looks like in Notepad. (I save everything in Tab delimited text files)
But it looks like 6 digits should be enough... Although beware of rounding when changing precision.
Message 6 of 22
(3,143 Views)
Thanks but that is not working for me. The raw data does not look like yours either.
I ran that code snippet and hand copied the result from the indicator to a cell in an Excel sheet and it will not convert - just shows pound signs as in my original post. I am using Excel from Office 365 - does that matter?
Message 7 of 22
(3,130 Views)
If it just shows # signs maybe try increasing the physical size of your cell.
Now Using LabVIEW 2019SP1 and TestStand 2019
Message 8 of 22
(3,123 Views)
The number is is the cell and I can see it in it's entirety, all attempted conversions results in excel showing pound signs # no matter how big the cell is, my screen shot of Excel illustrates what I am seeing, even if I copy the number directly into the cell and try to manually convert it back.
Message 9 of 22
(3,117 Views)
I am going to have to see your code, because something weird is going on...
I have been doing it this way for years without issue, and we are on Office 365 now so it's not that.
Message 10 of 22
(3,109 Views)
