Convert vector .blf file to ASCII format using LabVIEW
Hi all,
I have a requirement to convert a .BLF generated by Vector CANalyzer to ASCII(.asc) with the help of LabVIEW.
I have used below Hoovah library to read BLF file, but I am not sure how to write a code to parse the data read and save it in ASCII format in .asc file
https://forums.ni.com/t5/Example-Code/Read-and-Write-BLF-Files/ta-p/3549766?profile.language=en
I have been searching a lot on the discussion forums, but there is nothing that is helping me out.
Can anyone post sample code here?
It would be really helpful
Message 1 of 8
(10,089 Views)
ASCII is just a convention that assigns characters to bytes.
What kind of output do you want, just human readable formatted and delimited text? You can give any extension you want to it. If other software later needs to be able to read the file, you need to know what it expects.
Message 2 of 8
(10,068 Views)
Hi Altenbach,
After reading a BLF file using Hoovah library I get a data in array of clusters format as shown in Screenshot1. I need to write that data in an .asc file in a format as shown in Screenshot2.
I am using write to text file function to achieve this . But I am not getting how can I write all the data row-wise in to a single file . Please find my VI attached herewith wherein I can just write the payload in the file. But along with that I need to write timestamp, ID, etc also column wise as shown in screenshot2. My VI is in LV2020.
Kindly guide.
Message 3 of 8
(10,061 Views)
You did not include your type definitions.
All you probably need to do is open the output file before the loop, format each array element into a row, and append to the file. Close the file once the loop is done.
(btw: your array to path makes no sense. Typical filename inputs are just strings, so wire it directly)
Message 4 of 8
(10,049 Views)
Accepted by SuLAB
I really don't know how all your cluster element relate to each field in the output string, so here's a quick draft as a starting point. Just add all your other fields to the formatting operation as required. Should be trivial.
You can use "format into file" to append.inside the loop.
Message 5 of 8
(10,042 Views)
Thanks Altenbach. It worked!! 🙂
Message 6 of 8
(10,006 Views)
it shows me that ZLIB Inflate_ogtk.vi is missing
Message 7 of 8
(8,149 Views)
Open VIPM, search for the "OpenG LabVIEW ZIP Library" and install it!
Rolf Kalbermatter  My Blog
Message 8 of 8
(8,141 Views)
