Details from a VI server reference
I have a Vi server reference from a color box and I'd like to get the Control label name from the reference because I want to use it for a case structure
(908 Views)
  1. What is the question?
  2. Where is the code (a file with the extension ".vi")?
(886 Views)
Hi Bob
The question is above and in conjunction with the attached picture. I'd like to get the label name (highlighted in red, see pic) out of the vi reverence.
(846 Views)
Drop a Property Node on the Block Diagram (Application Control palette). Wire your reference to the Property Node.
The property you need is Label -> Text
Paolo
(842 Views)
Simply place a property node on the diagram and connect the refnum to it. Then select the property you are interested in and wire it up.
Rolf Kalbermatter
DEMO, TU Delft
My Blog
(836 Views)
Hoi Rolf
Herzlichen Dank!
(813 Views)
