Convert integer to date
Hello.
I have a question. I am importing some data from an excel file and a column of the data is in the date format. In LabView I am reading a number for example 4577. I know that the excel time reference is different from the labview reference and I am using this conversion factor:
However my problem is that I do not know how to convert this number into a date string in the form DD/MM. I just want to display in LabView.
Any help would be appreciated.
(4,014 Views)
see here
"Should be" isn't "Is" -Jay
(4,010 Views)
Accepted by topic author luisgepeto
luisgepeto wrote:
However my problem is that I do not know how to convert this number into a date string in the form DD/MM. I just want to display in LabVIEW.
Just set the Display Format of a numeric indicator to "%<%m/%d>T".  LabVIEW will take the time and format figure out your month and day for you.
(3,961 Views)
