Convert current to temp
I'm just getting started with Labview, I have a cRIO-9047 and a 9208 (4-20mA) card, I'm trying to figure out how to convert my current (4-20mA) reading to a temperature (0 - 200 F) reading before I get it to the waveform, and eventually one for pressure ( 0 - 500) to build up a little test stand:
I have so little knowledge in this area, I'm not even sure if I should be using that linear scale funtion.
Eventually I want to have multiple temp and pressure sensors on one user interface.
(1,730 Views)
Accepted by david123098
When you add the channel to the task, there is an input there to apply a scale.  That is what the scale reference gets wired up to.
(1,716 Views)
