Convert a string to an array of 16bit unsigned integers
I have a string represented in hex format, how can I convert this to an array of 16 bit unsigned integers?
I know I can use string to byte array to easily convert it to 8 but unsigned integers, is there a simple way for 16 bit unsigned integers?
(7,330 Views)
Accepted by hydzik
Use 'Type Cast' function.
String to U16[]
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(7,323 Views)
While your description is somewhat vague and not very clear, I think the typecast solution from the previous poster may not be what you look for. You may more likely look for something along these lines:
Rolf Kalbermatter  My Blog
(7,304 Views)
Thanks, type cast was what I was after.
(7,294 Views)
(1,024 Views)
