Convert a string to an array of 16bit unsigned integers
I have a string represented in hex format, how can I convert this to an array of 16 bit unsigned integers?
I know I can use string to byte array to easily convert it to 8 but unsigned integers, is there a simple way for 16 bit unsigned integers?
(7,398 Views)
Accepted by topic author hydzik
Use 'Type Cast' function.
String to U16[]
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(7,391 Views)
While your description is somewhat vague and not very clear, I think the typecast solution from the previous poster may not be what you look for. You may more likely look for something along these lines:
Rolf Kalbermatter  My Blog
(7,372 Views)
Thanks, type cast was what I was after.
(7,362 Views)
(1,092 Views)
