05-05-2010 01:14 AM
Hi, I see the following error when I downconvert the LV8.6 VIs to LV8.2, which uses objects.
Please let me know the fix for it.
05-05-2010 09:43 AM
Arvindti wrote:Hi, I see the following error when I downconvert the LV8.6 VIs to LV8.2, which uses objects.
Why are you posting in this thread? Your question has nothing to do with requesting someone to do a downconversion or upconversion. Please create a new thread with your question. Also, please make sure the full error can be seen. The item for "Block Diagram Errors" cannot be seen.
05-21-2010 02:06 PM
Is there anybody who can convert labview 8.6 to 8.2 ?
05-21-2010 02:14 PM
Please post a request in the Downconvert Requests thread. A separate Upconvert Requests thread exists as well for going up in version numbers.
Thanks.
07-08-2010 06:52 AM
hi,
i have a labview driver packet (LLB) which is in labview version 5.0. can someone convert it so that i can open it with labview 9.0
many thanks
07-08-2010 07:12 AM - edited 07-08-2010 07:21 AM
Hi Steffen,
don't you read was has been said just in the last message before your post? Please use the threads mentioned there...
Edit: Look here...
Edit2: See what happens: two people doing voluntary work for you when only one is needed...
07-08-2010 07:18 AM
Here. In future please post in the thread mentioned
07-08-2010 10:04 AM
thanks for your fast answer. i am sorry. it won´t happen again.
07-21-2010 08:20 AM
Good afternoon,
please could you convert for me some .llb, which should be in (5.1), we have (8.5) installed on our computer. Thank you very much!
Jindrich Sadil
07-21-2010 08:37 AM - edited 07-21-2010 08:37 AM
Converted here. In future stick to that thread
