Convert Labview 5.0 to Labview 8.5
Hello everybody,
Can someone plase help me to convert this Vi from labview 5.0 to labview 8.5?
Thanks in advance!
Message 131 of 152
(1,593 Views)
Post in this thread for the conversion. Have a look at the announcements section located at the main page in the forums once in a day to keep updated.
Mathan
Message 132 of 152
(1,580 Views)
Message 133 of 152
(1,567 Views)
I have a large library (.LLB) of VI's written in Labview 5.0, I've tried to open with Labview 2009 but it says the version is too early.  Could somebody please help convert these for me please?
Message 134 of 152
(1,536 Views)
I get this
Message 135 of 152
(1,537 Views)
Hi Reece,
seems you have to search for the "original" package instead of this size-reduced and "IP-protected" llb with stripped block diagrams...
Message 136 of 152
(1,531 Views)
Hello Muks!
Unfortunately, your error is likely the result of the original VI having its block diagram removed (a security option on saving VIs). You'll probably have to get hold of the original VIs (without the block diagrams removed) from the author/source.
For more info on removed block diagrams, please refer to this KB: KnowledgeBase 2N7DBEEW: What Happens When I Save My VI and Remove Diagrams?
Good luck!
Caleb Harris
National Instruments | http://www.ni.com/support
Message 137 of 152
(1,518 Views)
Anyone willing to convert this attached lib to LV 8.2 from 8.6?  The conversion to 8.5 worked out well.
Thanks in advance?
Message 138 of 152
(1,437 Views)
Thanks in advance?
Please in the upconvert requests thread. THanks.
Message 139 of 152
(1,425 Views)
Thanks in advance?
Actually the downconvert thread
Message 140 of 152
(1,419 Views)
