Convert 1D of String to 1D array of Double
Hello all,
Can anyone help me ?
I need to convert 1D arry of string to 1D array of Double
regards
(5,330 Views)
You convert the whole row into one string.
How you want convert this set of cells into single double?
Show example of your data
(5,315 Views)
Hello Artem,
Attached you can find the excel sheet and the VI that read the excel sheet and write it in Array
regards
(5,312 Views)
Accepted by SAED123
You have only one column or data, why you concatenate all into one string
here code
(5,301 Views)
My answer would be "Don't bother, read it in directly as an Array of Dbls".
If you make your range be only the rows with numbers, then you can simply read the data (and get a variant) and convert the Variant to an Array of Dbls.  If you have the Report Generation Toolkit, you can use it, but need to "fiddle" a bit to get just the data you want (calculate the "next row" and back up one).
Note the RGT needs a 2D array (or a single cell), but it will correctly return a 20-row by 1-col array (and you can extract the 1D Column array with Index Array, if you want).
(5,281 Views)
