Getting data from a PowerPoint document
Has anyone ever gotten data from a .pptx document with LabVIEW? If so, how?
PaulG.
Retired
(4,250 Views)
You can try use ActiveX (see example for word), but... what kind of data do you need?
(4,231 Views)
That won't work. I get a 3005 error when I try Automation Open a Powerpoint application.
It's just some data that would be really useful to grab directly from the document instead of convincing the powers-that-be that I need this document translated into something else. 🙂
PaulG.
Retired
(4,215 Views)
Accepted by topic author PaulG.
ActiveX is the way to go. The Power Point object model is very different from Word as it uses PlaceHolders shapes that contains a Text Frame. Attached is an example that you can use as a starting point, it shows how you can get text from a place holder. You can add additional checks to avoid errors like using the property PlaceHolder.HasTextFrame.
Ben64
(4,214 Views)
Thank you. This is helpful. May be more cost effective redoing the whole thing in Excel. Who documents specs in a Powerpoint presentation? Smiley Indifferent
PaulG.
Retired
(4,169 Views)
