10-23-2009 12:31 PM
10-23-2009 01:21 PM
A more efficient way may be monitoring the application to see if it lost activitate. If it does, then get the active window. And see the the active window title includes "warning" or something like that.
George Zou
http://webspace.webring.com/people/og/gtoolbox/
10-23-2009
01:55 PM
- last edited on
12-17-2025
10:12 PM
by
Content Cleaner
Your best bet is if this other application has an ActiveX interface, which is the most standard way for Windows applications to communicate with each other and automate various actions. LabVIEW can act as an ActiveX Server or Client if this other application has any such abilities.
10-23-2009 01:58 PM
10-23-2009 02:00 PM
10-23-2009 02:13 PM
10-23-2009
10:53 PM
- last edited on
12-17-2025
10:13 PM
by
Content Cleaner
You can use the Windows API to determine if this alarm window has been created. The Windows API Function Utilities (32-bit) for LabVIEW can help in this regards. Another option is to use something like AutoIt.
As for generating mouse clicks, that can also be done with the Windows API. This question has been asked dozens of times, so do a search for simulating mouse clicks and you'll find examples.
10-24-2009 02:03 PM
I start positing elements and analysing. Here is an image 'Beyond Control' snapshot: http://noneflight.notlong.com
Or an image in "Beyond Control": noteflight
10-24-2009 08:41 PM
noneflight wrote:I start positing elements and analysing. Here is an image 'Beyond Control' snapshot: http://noneflight.notlong.com
What exactly are you talking about?
10-24-2009 09:28 PM
A really bad spammer? I always get suspicious of anyone who has posted exactly 1 time, and it is only a couple minutes after creating their login name.
