FPGA FlexIO: how can I get 250Mhz clock from 40Mhz clock on board pxi-7954?
Hi!
I hope to get 250Mhz clock from 40Mhz clock on Pxi-7954.
I need 250Mhz clock with 0 phase/90 phase/180 phase /270 phase.
I don't how to do....
(3,705 Views)
You can generate a derived Clock by right-clicking the "40MHz Onboard Clock" in your project and select "New FPGA derived Clock".
Christian
(3,671 Views)
Thank you!
I need four phase clock with 0 degree,90  degree,180degree,270degree.
use  clip ,I can  get  it, but  compiled error.
(3,653 Views)
To have a 250MHz clock with 90/180/270/360 degree phase shift, you would need a 1GHz clock (4 times faster) to add the necessary delay to each of the clocks.
This is not possible with this hardware.
Christian
(3,644 Views)
You'll have to instantiate a PLL in a CLIP to get the 4 different phases of the 250 MHz clock.  You can instantiate this manually or use the Xilinx coregen GUI.
-RB
(3,635 Views)
