Controlling a VFD using Modbus/TCP or Ethernet/IP using LabView?
It looks stretched, but now it is showing.  Play with the width and height that is in the HTML.
Message 21 of 26
(2,826 Views)
Now?
Message 22 of 26
(2,823 Views)
Now it's looking good.
Message 23 of 26
(2,810 Views)
hi please could you tell me how to use rs485 to control VFD i use delta vfd and USB/rs485 it is first time i use labview so i don't know if i have to use visa read/write or serial protocol or modbus master/slave delta provides communication protocol i want to control of speed and monitor torque according to load change
Message 24 of 26
(2,257 Views)
Hey nagham777!
This post is over a year old, for the best chance at visibility, I'd recommend creating a new forum post with more information. I'd also recommend creating it in the Instrument Control forum. Best of luck!
Claire M.
Technical Support
Certified LabVIEW Developer
Message 25 of 26
(2,239 Views)
@pRoF1T Were you ever able to resolve this issue? I have an identical setup and am running into similar issues. I can see the device on the network, I can log into it via a browser and adjust settings but I cannot establish a connection to it using the ABB Drive Composer application or via LabVIEW. Any pointers much appreciated!
OG
Research Engineer
Message 26 of 26
(1,611 Views)
