Control that supports copy-paste from Excel?
Hi!
Is there a control that supports simple cell copy-paste from Excel?  I'm making a program and a lot of data I can envision my user copy-pasting from Excel spreadsheets.
Arrays don't work and Table controls don't work...
I've found an ActiveX control called "Microsoft Office Spreadsheet 11.0."  That works, but I don't like the idea of my code being dependent on a particular version of Office being installed.
Any help is appreciated!
-nic
(4,560 Views)
Accepted by topic author hecmar.arreola
You can use an invoke node App.Clipboard Read to get the data in tab-delimited format. You can then manipulate this string data into your array or table.
cheers
David
(4,551 Views)
Thanks for the response, David.
I'm browsing through the various events available, and not seeing what I am looking for.  Is there a way to detect a "paste" event into my table control.  I could do some "Key Down" type events  I suppose.  I could also use a button "paste into table" or something...
-Nic
(4,544 Views)
Apparently "Ctrl-V" will not generate a "Key Down" event because there is a Menu shortcut with Ctrl-V....
(4,542 Views)
I think using a button to action the paste of the data will be your easiest option to try and see if it works out OK for you functionally.
(4,539 Views)
If you use a 'Menu Selection? (App)' event, you can look for the 'APP_PASTE' ItemTag, discard the usual event and do your own paste.
(4,535 Views)
Weeeeee..... well, that was fun.
The only issue with the "Menu Selection? (App)" event is if I wanted to have paste features elsewhere.  I think I'll end up using a button for pasting...there is an issue with the attached code that if the user is "in" a cell, that cell doesn't get the pasted data.  There is also an issue if the user wants to paste a single string to a cell in my table as oppose to strings from an excel spreadsheet.
-nic
(4,510 Views)
