remote panel invalid ip server
hi i´m trying to control a remote panel from other computer using internet, when i open from my computer i works well. when i open from other computer it opens the page but is shows a message"invalid ip server". i put the code generate to view the front panel. 6-2 Temperatura promedio actual
Text that is going to be displayed before the image of the VI Panel.
<SCRIPT language="JavaScript"></SCRIPT>
Text that is going to be displayed after the image of the VI Panel.
(3,225 Views)
Hi Syd_b;
The error you are receiving is probably being generated because the LabVIEW Web Server is not enabled in your machine.
I hope the information is useful.
Good Luck
Francisco Arellano
National Instruments Mexico
Field Systems Engineer - Energy Segment
www.ni.com/soporte
(3,176 Views)
thanks for help it work fine.
(3,166 Views)
