Two VI merging (a Temperature PID and Light sensor detecting) plz help
my goal is to get the data from the light sensing detectors and also to control the Temperature too.
So I designed a VI named Light detecting "sensor and data storage.vi" but the problem was temperature controlling.
as in this VI I can not set the temperature which I want.
So I made another VI named "temperature control PID.vi", and now I can control the temperature through the thermocouple.
But again the problem is that I can not run Both the VIs at the same time.
and when I try to run both the VIs at same time, the following error appears,
and I think, it is because that both the VIs has the settings for same thermocouple and can not acquire the data (teperature) at the same time.
So I want to remove the thermocouple settings from the "Light detecting sensor and data storage.vi" and want to put the " temperature control PID.vi" into it.
I am uploading both the VIs, If anyone can solve it, His work will be appreciated.
Message 1 of 11
(4,879 Views)
Did you try doing a search for that error code? You've made a very common mistake and the answer is to simply have both channels in the same task. In your first VI, you would add another DAQmx Create Channel to the task.
Message 2 of 11
(4,876 Views)
But I want to make only one VI from the above two VIs. How can I merge these two?
Message 3 of 11
(4,856 Views)
Message 4 of 11
(4,848 Views)
But how to merge these two VIs? I cant do it by myself.
Message 5 of 11
(4,825 Views)
Why not? You created the original VIs didn't you? As I said, you just have to add another DAQmx Create channel to your first VI, this will define the termperature channels(s) that you have in the express VI. These new channels are new elements in the waveform array that you get back with the DAQmx Read. Index these out the same way you indexed out the other channels.
Message 6 of 11
(4,818 Views)
Dear DENNIS KNUTSON,
I have attached the VIs. please modify it and upload it for me.
then I will check, whether it will work or not?
thank u very much for helping me.
Message 7 of 11
(4,796 Views)
I mean to say that from the first VI, i m getting the signals from detectors and it also shows me the temperature. but from this VI, I can not set the temperature of the heater.
thats why I made another VI <the second one in attached files> by which I can control the temperature.
but both the VIs are not working simultaneously.
so plz delete the temperature settings from the first VI and put the second VI into it.
thanks.
Message 8 of 11
(4,773 Views)
Hi akhpal,
You will not be able to aquire the data at the same time from two VIs. You should collect it in one place and apss it on.
Flash
Message 9 of 11
(4,752 Views)
I have attached the VIs of Both. could you finish the settings of thermocouple and output amperes <current> from it. and then putting the PID into it.
Message 10 of 11
(4,740 Views)
