Control System for a Windtunnel
My project is to implement a control system for a wind tunnel
- Labview 2014 to do user interface and control system
- 2 load cells to gauge Lift and Drag.
- a Linear Servo to change vertical elevation of the object.
- 2 amplifier circuits to increase voltage of load cells for reading.
This is all to be control by a USB 6008 board. Current problems stem from the linear servo which needs a PWM signal to control position. To contol it we need a variable duty cycle with about 500 Hz and 5V.
Linear Servo - https://www.servocity.com/hdls-6-50-12v
My question is can USB 6008 do a PWM signals? If yes can it also preform all these other tasks? If Not what Board could do this at a budget of close to $800
(4,555 Views)
I assume this is a "real project" and that the data from the Wind Tunnel might be important.  So whether or not the USB-6008 can handle the PWM or not (have you read the manual?), why would you use a Legacy device when NI has come out with the 6001, faster, more bits of A/D, etc.?  It may even be less expensive ...
(4,530 Views)
Accepted by ByInspection
For servo you need PWM signal changing from 1 ms to 2 ms. 6008 can not do it. The first usb that can is 6210, it fits the budget (654).
It also has analog outputs, 125 kS/s/ch with 2 active channels, 16 bit should be enough
Having something like Arduino to position servo and 6008 to read position will be a cheaper (if analog speed, resolution enough) but more time consuming solution, depends on your experience and exact task.
(4,528 Views)
If you knew analog ICs, you'd find the "timerblox pwm"; http://www.linear.com/product/LTC6992-1  This would take up one analog out of the 6008 and convert it to PWM...  I've done PWM with 8 channels using a 6009 - at 10 Hz through.
(4,476 Views)
Thanks for your replies!
I neglected to mention a couple of things about the project
-We are doing data aquisition by saving lift and drag to an excel file.
-We what to control wind speed which needs voltage of 0 to 10V
I have been looking at the 6210 and it seems to have just about all the qualities I desire, with one exception. It does not have any analog out ports. We want to have a virtual potentiometer to control wind speed, but the only way I know how to do that in LabVIEW is with a DAQ Assists Voltage output which is connected to an analogy out port. Do you know of any ways to do this from a digital port?
Also the Arduino is a good idea and one that worked, but we are only allowed National Instrument devices for the control systems.
(4,446 Views)
Hello ByInspection
Have you checked the USB 6212?
http://www.ni.com/en-us/support/model.usb-6212.html
That one includes 2 AO.
Diego H
National Instruments.
(4,415 Views)
