Control Porperties
Accepted by topic author hrsnblm
I see the full property page for that control when I opened your VI.  So I don't think it is a problem with your VI or your control.  I think the issue is with your LabVIEW install.
Message 11 of 13
(1,266 Views)
> There is no "32.txt" file in this folder or any other LabVIEW 2016 folde
If you are using 64bit LabVIEW, the path would be:
"C:\Program Files\National Instruments\LabVIEW 2016\resource\PropertyPages\32.txt"
If you are using 32bit LabVIEW, then that's the problem.
The PropertyPages should looks like this:Untitled.jpg
George Zou
Message 12 of 13
(1,261 Views)
Though I tried everything suggested, nothing seemed to have an impact until I did a repair/reinstall of LabVIEW 2016. Once I went that process, and all the updates, it now appears to be performing correctly.
Thanks for all the assistance.
Message 13 of 13
(1,241 Views)
