Control Of Sabertooth 2x60 with packetized serial
Hello all,
I am trying to get a driver built and fully working for a Sabertooth 2x60 to be used in a RoboRIO driving an electric wheelchair motors.  So I have it working for the most part and it should be a real simple but for some reason it is not.
I can post additional code if it helps but hopefully someone has had experience with the issue.  I and sending serial commands to the sabertooth via VISA and it responds perfectly for motor 1 and seems to miss about every other message for motor 2.  Additionally I cant set the serial time out or any of the other time outs.
Attached is a summary that I sent to Customer support but so far they are little help.  I am guessing it is some random Labview thing that I am missing.
Thanks for your help!
(3,310 Views)
Accepted by topic author GeneHancock
Your checksum says you want to add the 3 bytes together.  But you are just ORing them together.  Before ANDing with 1111111.
In some situations, the checksum would be the same.  In others it would not.  (Though for the 2 examples you show, they do give the same checksum.)
(3,254 Views)
Crap I think that is the issue.  I will test it out when I get to work but it makes total sense.  I think I just say the + and thought or and didn't fully read it.
Will Update when I know it works.
(3,249 Views)
That was the issue.  Good eye.
(3,236 Views)
