08-25-2006 06:58 AM
09-01-2006 05:54 AM
09-12-2006 08:40 AM
09-12-2006 09:12 AM
09-26-2006 12:25 PM
just wondering how you got on with the advice from Kirt??
Your code architecture is a loop with a case statement. If the start button is false, then you clear the task, thereby removing it from the valid tasks list in the driver is that correct? (You have it set to true on loading the vi).
I can load the vi fine, and don't see a blue screen so I don't think the vi is corrupt and therefore this should just be an installation issue.
If you could give us an update, that would be great.
Sacha Emery
National Instruments (UK)
