No output from DAQ Assistant after calibration
My data aquisition worked fine until I calibrated the channels. I am reading  60 analog voltages (0-5vdc) from a pci-6225 using DAQ Assistant.  After the calibration my program still ran but DAQ Assistant is not outputting any values.  I tried probing the line on the output but I see nothing.  The program thinks it is sending the data to file but the file is blank except for the header.  When I turn off calibration it works fine. Any ideas about what I did wrong?
(2,485 Views)
(2,464 Views)
