Connecting multiple thermocouple indicators to one DAQ Assistant block diagram
If you are trying to wire directly to the breakout board it will not work. When I create a virtual channel it tells me that I need a SCB-68. This is a signal conditioner as I talked about yesterday. I think you are just missing the signal conditioner part. I do not believe that you wire directly into your breakout board and expect this to work.
Tim
GHSP
Message 11 of 14
(3,675 Views)
Accepted by topic author Squinn21
Hello Squinn21,
After looking at your VI, it appears that you have the exact same wire going into each of your thermocouple wires.  While dynamic data types do have a certain amount of "magic" assoiated with them, they will not automatically split their value between multiple indicators.  Instead, try using a "split signals" to separate your channels.  When you're done your code should look something like this.  Hope this helps!
ColeR
Field Engineer
Message 12 of 14
(3,663 Views)
I have been following this posting and I have the same issue as the originator.   I have build the VI to match the diagram as provided, but when I attempt to split the signal from the DAQ Assistant data output, I can only wire from one terminal on the output of the splitter.    My DAQ assistant in set up for measuring 16 thermocouple channels from two SCXI 1112 boards installed into a SCXI 1000 chasis.   The A/D is accomplished using an SCXI 1600 board also installed in the Chasis.  When I run my VI only the first channel works.    I have the data terminal wired from the DAQ Assist to a Write to File Experss VI with a dynamic data wire.  When I save the data to a file, I can see that all 16 channels are about the same as the 1st (small variations) even when I have only 1 or 2 themocouples connected.   It seems as though the DAQ Assistant only outputs a single channel.
Message 13 of 14
(3,563 Views)
OK... I found in another posting that I needed to expand the splitter up and not down in order to create multiple terminals.   With that done I could wire each split from the data output of the DAQ assist to an individual numeric indicator, but they all still read the (approximate) same value!  If I raise the temperature on one thermocouple, all indicators rise.   The data written to file show the same results.   Even those channels without a thermocouple connected read and respond the same.
Message 14 of 14
(3,560 Views)
