Connect LabVIEW and Universal Robots via RTDE (real time data exchange)
but anyway: here is a vi - built on my previous vi`s to capture TCP data into a txt file - have fun 😁
Message 21 of 26
(1,252 Views)
In this message you explain that you were able to connect the robot in different ways to the robot, Im relative new to the usage of the LabVIEW. And I can make the connection but I´m failing to give a Command of Start, Pause and Stop.
Could you explain me how to make the Loop with the TCP?
Message 22 of 26
(1,225 Views)
for the hole explanation it was really helpful, but when I´m not an expert, how can I send more than one variable of information. I want to send 5 different values. How can I make that possible?
In other hand is there a way to send a Script from Labview, that would make everything easier if I could send the code directly and that the robot receive it?
Message 23 of 26
(1,220 Views)
Hey!
To use LabVIEW to connect to additional input registers, you just need to add an entry to the text array as shown in the image:
To enable the UR to read the data, the registers (at least for the URe series) are read out as follows:
In the case shown, I write the data to an array (tmp). Since I do not send joint-angles here but TCP positions, the content is valid for the inverse kinimatics command via tcppos=p[,,,,].
I hope this helps a little,
best, Alex
Message 24 of 26
(1,192 Views)
btw: Often the connection via RTDE is not even necessary! Port 29999 allows you to connect and send start and stop commands (and more) to control UR5 programs.
This should help:
https://www.youtube.com/watch?v=S1oEeiL19p4
and
https://www.youtube.com/watch?v=ivvHDBrgh-8
I did that way and it worked nicely!
Message 25 of 26
(1,183 Views)
It's been a while since you last posted here, but do you know how I can extract pose data from the UR Robot using this TCP connection method (from your main.vi)? I was able to get it running and verify the connection!
Thank you so much!
Message 26 of 26
(884 Views)
