Connect LabVIEW and Universal Robots via RTDE (real time data exchange)
Finally finished, here are the instructions: The Universal Robots Real-Time Data Exchange (RTDE) and LabVIEW
I hope you can do something with it!
You will also find the corresponding VIs in the appendix - I look forward to suggestions and improved functions 😁.
Best!
Alex
Message 11 of 26
(3,479 Views)
Thanks for the work, i've tested with a UR10e V5.11.5 and LV2020 and it work. There is a small problem. The library is using a control that is not in included in the llb. I've just "Disconnect from typedef" and work just fine.
Message 12 of 26
(3,413 Views)
great that it works! oh yeah, oops no idea how that happened - should be a normal variable.
Message 13 of 26
(3,406 Views)
Hello, thanks for the super helpful guide!
I tried using your VI to get the force values from a UR5e robot onto my computer but I'm struggling to get it to work. I thought it would be as simple as changing the requested output to actual_TCP_force but the data I get back is gibberish. I tried hardwiring the bytes to read to 56 (I have safety_status and actual_TCP_force as outputs) as it seemed it was calculating the wrong value but that didn't seem to fix it.
"Parse error package invalid" also shows up in "data out" in the RTDE_VECTOR3_6D_2_Array.vi which I'm not sure how to fix.
For clarity, there are no errors in the actual VI itself, everything connects and runs fine, but the output data either stays at zero or jumps wildly between insanely high and low numbers. If anyone could provide any insight into how to successfully output force data it would be greatly appreciated!
Message 14 of 26
(3,025 Views)
so I tried this out quickly:
unfortunately can not find any error, the data actually looks better than I thought. Please try it with the attached vi. TCP_forces.bmp
Message 15 of 26
(2,993 Views)
Thanks so much for the quick reply! Sorry for the delay on my end, but the program can't find the build_array.vi which I assume is a subVI you created. Could you share that VI as well? Thanks!
Message 16 of 26
(2,921 Views)
Oh sorry!
Message 17 of 26
(2,889 Views)
Thank you it works great! I suppose it was just formatting differently
I do have another question for you or anyone. I'm trying to write the force data to a csv file, I used the "export waveforms to spreadsheet file" function which works but only shows the most recent 100 values (whatever values currently show on the graph). How can I show all the value history in the waveform graph but more importantly in the file? I also tried getting the waveform components, converting them to fractional strings, concatenating the strings then writing to a text file but the formatting of the file was all messed up. Admittedly I am really new to labview so sorry if this is a silly question and thanks for any input!
Message 18 of 26
(2,874 Views)
Yes, It would definitely be worth it as many people are still struggling to find a way to communicate with UR via RTDE using LabView.
Message 19 of 26
(2,240 Views)
Sorry, just saw your question - if you still need help - I think it is in the wrong place here!
Message 20 of 26
(2,233 Views)
