Conflict between 2 projects
I have a file called driver.dll in project A.
I have another file called the same driver.dll in project B, but driver.dll in project A is not the same than driver.dll in project B.
My 2 projects were working correctly but I had to made some modifications inside driver.dll in project B.
And the main vi of project B uses the sub vi inside driver.dll from project B.
"Project B" works then as I want after modifications however "Project A" doesn't work anymore because of the modifications I have done in driver.dll inside project B.
The main vi of project A use the sub vi inside driver.dll from project B, not anymore from driver.dll inside project A.
Why ? I guess it is because I have created new sub vi in driver.dll from projectB, and as projectA doesn't see where the new sub vi are, projectA redirects toward in driver.dll from projectB.
See the picture embedded.
My question is how can I avoid conflicts to have back :
- driver.dll from project A on project A
- driver.dll from project B on project B
Thanks for any help,
Fabien
(3,929 Views)
Make sure you never open a VI from project A while you are in project B.  Once that cross-linking has happened, about the only way to get it back is to move Project B to somewhere else on your harddrive, open Project A and fix any missing dependencies (ie links that were to Project B), and then put project B back.  Make sure you take care of the other way as well (move A, fix B, restore A).
(3,898 Views)
Rename project B's folder, open project A and relink to the right DLL. Save and never open both projects at once, basically. (You can e.g. lower risk of cross linking by opening 2 LV instances instead of 2 projects in 1 LV if you need both (this can be done vis a subst-command so you have 2 LV 'paths')
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,894 Views)
A better way would be to have a VM for each project.  But that is another story...
(3,891 Views)
Accepted by fabien-g
I am certain I never open both project at the same time.
And most surprisingly is that, I restaured project A from an old save copy that were working perfectly and I renamed as project C and it didn't work anymore.
I had to solve my problem by redirecting manually each confusing link. It teared my hair out.
Thanks for your response,
Fabien
(3,871 Views)
True. It costs some performance though.
/Y
Qestit Systems
(3,853 Views)
Yes exactly.
Split the hard drive and use a unique project for each partition is a solution that works perfectly.
I finally use that solution.
Fabien
(3,823 Views)
