Conditionally add value to array
Hello all,
I have two 2D arrays of string data in my VI (taken from an .mdb file using ADO & SQL). The "window list" array on the left is what I want to append values to. The "glass list" array on the right contains values that I want to add to the main table depending on the values of other cells.
For instance:
Window 1's Pane ID's are 2191 and 2001. Under Pane 1/Pane 2 thickness in the "window list" table, I would like to add the appropriate thickness for Pane ID 2191 and 2001 from the "glass list" table.
Below is a snip of the two tables in question.
This should be quite simple, but as I'm a LV rookie I'm not quite sure how to do it.
Many thanks,
Laura
(3,370 Views)
Accepted by topic author lauraalkhoury
Attached should be what you want.  Let me know if you have more questions.
(3,354 Views)
Absolutely perfect! Thank you so much.
(3,349 Views)
