USB camera connection - problems installing NI-IMAQ for USB Cameras
I tried to install the usb camera application from http://zone.ni.com/devzone/cda/epd/p/id/5030
unfortunately it does not work. I can not find the usb icons in my function palette. can you please help me?
I only want to connect a usb camera with labview. how hard can it be. any help would be much appreciated.
cheers
Message 1 of 10
(6,680 Views)
Hi
I installed NI-IMAQ  on LV 8.6
Then found this IMAQ.lib for the USB Cameras and use this lib in LV 2009...
Message 2 of 10
(6,675 Views)
Its a very simple thing and depends on the version of the LabVIEW you installed. If you have version LV2009 or later you have inbuilt module for USB camera and when you go into the Vision assistant you can use the web cam which is connected to the PC.
Message 3 of 10
(6,671 Views)
Accepted by topic author DEUS
First, you need to make sure the USB camera is DirectShow compatible.  If it isn't it will not work with our vision software. You need to use the IMAQdx drivers (which requires a license) to acquire from a USB web cam.  Once you have the IMAQdx drivers (Vision Acquisition Software) installed and the drivers that come with the camera installed you should be able to see it in Measurement & Automation Explorer (MAX).  Once you can see it in MAX you can use it just like any other camera in LabVIEW.
Greg H.
Message 4 of 10
(6,654 Views)
Yes you should have the camera Directshow compatible but once you have that I don't think you need to have License for that you can play with the webcam in evaluation copy itself but while building the exe and the Installer you need a license.
Message 5 of 10
(6,646 Views)
Hey guys,
thank you for your help. I found out that my liscence for labview vision was not activated and i did not install all the drivers and therefore i could not use the IMAQdx. Smiley Embarassed
Cheers
Message 6 of 10
(6,633 Views)
when i install imaq for usb camera .exe,a pdf is oppened:((( can someone help me pleaseeeeeeeeeeeeeeeeeeeee
Message 7 of 10
(6,580 Views)
What version of the drivers are you trying to install and where did you get them (i.e a disk, ni.com, etc.)?
Greg H.
Message 8 of 10
(6,562 Views)
i'm using labview 2010 i got it from a disk i have vision builder 2010and i have windows 7 64bit
Message 9 of 10
(6,549 Views)
Do you know what version of the Vision Acquisition Software you are using?  I would suggest you download the latest drivers from our website:
http://search.ni.com/nisearch/app/main/p/bot/no/ap/tech/lang/en/pg/1/sn/catnav:du/q/vision%20acquisi...
Greg H.
Message 10 of 10
(6,538 Views)
