05-02-2012 09:41 AM - edited 05-02-2012 09:42 AM
Hello all,
I have two 2D arrays of string data in my VI (taken from an .mdb file using ADO & SQL). The "window list" array on the left is what I want to append values to. The "glass list" array on the right contains values that I want to add to the main table depending on the values of other cells.
For instance:
Window 1's Pane ID's are 2191 and 2001. Under Pane 1/Pane 2 thickness in the "window list" table, I would like to add the appropriate thickness for Pane ID 2191 and 2001 from the "glass list" table.
Below is a snip of the two tables in question.
This should be quite simple, but as I'm a LV rookie I'm not quite sure how to do it.
Many thanks,
Laura
05-02-2012 10:04 AM
Attached should be what you want. Let me know if you have more questions.
05-02-2012 10:19 AM
Absolutely perfect! Thank you so much.
